 Black knight F3p 11g
Aller à la page : 1, 2  Suivant
cristiandinu
Nombre de messages : 11
MessageSujet: Black knight F3p 11g   Jeu 25 Sep - 9:18
Hi,
I recently buy 2 Black knight 11g brushless motor. Initialy on the description it say 296 g traction ... now it say 200g traction. So i made This engine is ok for f3p on Aito ?
I have also 25 g 400 mah lipo and 6 g servos, 5 g ESC and 5 g receiver .
Anyone has this combo ?
Also .. the motor has 4 wires ... wich ones are for the controler ? 3 wires are somehow group together ... I will put some pictures .
Tork
Tork
Nombre de messages : 79
MessageSujet: Re: Black knight F3p 11g   Jeu 25 Sep - 11:44
You have the perfect combo for an aito (I think than 400mA is perhaps too, it's realy good, but a 300mA is better for your combo)
If you're meticullous during the construction, your aito will be under the 130g!
Yes, put somes pictures of your motor because i don't understand the story of the 4 wires lol
MessageSujet: Re: Black knight F3p 11g   Jeu 25 Sep - 17:57
Dear Christian
Don't worry about the power of the BK11.
yes it was first written 296g trust but this was with a power supply. After our tests we found out it was a bit more than 230g with a standard 300 2S mAh.
So we prefered to say it was only 200g trust in order to have better performances than annouced
About your Aîto don't worry.
The Aîto can come really light (specially with this motor).
With a 2204/54 we get it at 165g with 450mAh batteries
With the BK 11g you should get it at 150g or so.
Use enamalled wire to lighten the servos.
also i suggest you to install the elevator servo close to the Rudder servo and use Push-Pull wire to move the elevator.
Another idea to lighten the plane is to thin the fuselage sides up to 1.5mm thickness.
use enemalled wire to replace receiver antenna and solder the enemalled wires of the servos directly to the receiver plugs.
in this matter you could get your atito around 130g or less.
Our lightest Aîto was 126g flying weight with the following equipments:
Motor: AXI 2203/46 (18g)
ESC: PHX 10
Lipo: 2S 300mAh
receiver: 5g
prop: 8x4.3 GWS
3pcs of 6 gramms servos lighten to 5g
About the 4 wires, check carrefully, maybe a wire unsoldered from another wire group. you just need to resolder to it.
really you do not need to worry
Anyway, if after your testings, you feel like you would need more power, you can send me back the BK11 and i'll replace them for AXI motors.
best regards
Jérôme
cristiandinu
MessageSujet: Re: Black knight F3p 11g   Jeu 25 Sep - 20:27
Thank you for quick response .
The picture of the BK http://www.flightaddicted.ro/gallery/main.php?g2_itemId=2933
Anyway... right now 130g for aito seems to me misson inposible. After I weight the plane and electronics I got 180 g without CA.. The plane weight 99 g empty.
Can you show me how to open the servo .. there is no screws . For this servo
http://shop.donuts-models.com/boutique/fiche_produit.cfm?type=94&ref=04DM-EP6_0&code_lg=lg_fr&pag=1&num=18
I'll search on the internet how to thin the fuselage.
I'm not worry .. i'm sure everthing will be just ok.. i just need some guidance.
MessageSujet: Re: Black knight F3p 11g   Jeu 25 Sep - 23:38
Ok got the picture
Don't worry worry about N°1 it is normal the 3 phases are N° 2,3 and 4
To thin your fuselage use an electric rabot (not sure of the english term)
Anyway you can do it by sanding of with Hot wire.
About your battery, try to use a 300mAh not more than 16g
your 450 2S is quite heavy.
lighten your receiver(take off the shrink tube around and replace the antenna by enameled wire.
for servos take off the Stikers and take off the bottom of servos, and replace all the wires by enamelled wire (2/10)
Do replace the ESC silicone wires by enameled wire and whorten the BEC wires.
Try to use the less glue you can (for exemple i can Build 7 planes with only a 20g CA glue bottle)
Then you could reach the lightest weight
as i said an Aîto with 2204/54, PHX 10, 3x EP 6.0g servos, 5g receiver and 25g lipo battery we always get 165g
99g for the Foam parts of the Aïto is strange. Maybe something wrong with your weighter. i'll recheck tomorrow
Anyhow, if you cannot reach 140g i'll replace the BK 11 motors for AXI 2204/54. then no more problesm for you.
My first purpose it to have happy customers
Please advise.
best regards
Jérôme
cristiandinu
MessageSujet: Re: Black knight F3p 11g   Ven 26 Sep - 11:29
99 g is the weight with accesories and carbon rods.
The foam weight 89 g.
Maybe my weighter is off scale ..
I have a rotay tool from proxxon (something like dremel tools ) ... i think I need a suport for the tool and a steady hand.
Changing the wire is a simple operation...
I'll keep you posted..
MessageSujet: Re: Black knight F3p 11g   Ven 26 Sep - 13:05
Ok Christian
please keep us informed
Jérôme
claude66
Nombre de messages : 21
MessageSujet: Re: Black knight F3p 11g   Sam 27 Sep - 22:06
bonsoir Very Happy ,une question sur ce moteur son poid de 11gr est t'il le moteur seul ? ou avec un de ses supports? Question A bientot,Claude Wink
MessageSujet: Re: Black knight F3p 11g   Dim 28 Sep - 1:29
Salut Claude
Les 11g c'est le moteur avec son prop saver
Le Bati radial doit faire dans les 1.5-2g
mais personnelement, je colle direct le moteur sur ûn bâti PVC
Jérôme
claude66
MessageSujet: Re: Black knight F3p 11g   Dim 28 Sep - 11:02
ok Jerome Wink ,penses tu que ce moteur sera suffisant pour faire remonter facilement un avion qui avec ce moteur ferait 140gr? Rolling Eyes ?A +,Claude
MessageSujet: Re: Black knight F3p 11g   Dim 28 Sep - 13:03
Salut Claude
Cela dépend de ce que veux vraiment en faire
à 140g je conseille ploutôt l'AXI 2203/52 ou alors le tout nouveau CBM quis sera dispo d'ici 2-3 semaines.
Jérôme
claude66
MessageSujet: Re: Black knight F3p 11g   Dim 28 Sep - 20:44
disons Jerome que c'est pour du f3p ,sinon c'est autre moteur que tu vas avoir bientot,c'est du light aussi avec un kv equivalent,à+,Claude Wink
red sky
red sky
MessageSujet: Re: Black knight F3p 11g   Lun 29 Sep - 15:23
DONUTS a écrit:
...replace all the wires by enamelled wire (2/10)
Hi,
I also try to lighten my Nexus as much as possible. Can you tell me, this enamelled wire, what section should be? maybe in squared mm... I don't know what 2/10 means.
Tork
Tork
MessageSujet: Re: Black knight F3p 11g   Lun 29 Sep - 17:04
Hi,
2/10 means 2 mm, now if Jerome can comfirm
cristiandinu
MessageSujet: Re: Black knight F3p 11g   Lun 29 Sep - 18:53
2mm ??????????????
maybe 0.2 mm
MessageSujet: Re: Black knight F3p 11g   Lun 29 Sep - 23:39
Hi
yes it is 0.2mm
Best regards
Jérôme
Tork
Tork
MessageSujet: Re: Black knight F3p 11g   Mar 30 Sep - 11:00
ça c'est 2/100 lol
MessageSujet: Re: Black knight F3p 11g   Mar 30 Sep - 14:44
euh
2/10 de mm bien égal à 0.2mm non?
jérôme
MessageSujet: Re: Black knight F3p 11g   Mar 30 Sep - 14:53
je suis pas sûr que tu gagnes en poids si tu mets du fil émaillé de 2mm de section cyclops
Tork
Tork
MessageSujet: Re: Black knight F3p 11g   Mer 1 Oct - 21:43
ué lol 2/10 de mm c'est bien 0.2 mm ...
Mais pour moi 2/10 c'est 2/10 de cm, du moi c'est ce que je vois en élec à la fac lol!
MessageSujet: Re: Black knight F3p 11g   Jeu 2 Oct - 15:55
ok lol
tout s'explique
jérôme
cristiandinu
MessageSujet: Re: Black knight F3p 11g   Mar 2 Déc - 0:33
Hi ,
I have finished my aito .. I have milled soldered.. glued .. and the result is ...165 g.. I don't know how you guys make 130--140 g.. I have milled every cm.. Anyway a friend a-of mine has one at 180g with axi 2203 and it flies verry well.
Here are some pictures with the building. http://www.flightaddicted.ro/gallery/main.php?g2_itemId=4074&g2_page=3
I think next weekend i will try .. the first one with black kight .. and the second one i will use axi 2203 or 2204 ...
If it doesn work with black knight i will buy a vega or a click..
Thanks
Cristian
MessageSujet: Re: Black knight F3p 11g   Mar 2 Déc - 0:40
dear christian
Well that sound strange, built my litest AITO milt only on the fuselage and the Weight was 129g with an AXI 2203 and 3 lighten servos and 300mAh batteries.
165g Aitos are non milled version with only ESC, Servos and receiver leigthen.
standard Aïto weight out of the box is between 170 to 180g (depending on glue)
Anyway don't worry the BK 11 has 255 g trust.
If you don't think enough power, and if you want change plane i suggest ELIPSIA; THE elipsia can fly at 140 to 150g as slow as an vega at 110g
because of high wing area and ultra reactive availability.
best regards
Jérôme
MessageSujet: Re: Black knight F3p 11g   Mar 2 Déc - 0:44
Christian
i am really amazed
i saw your pictures and an Aîto such as yours milled like this should weight around 120g no more.
Really strange
What batteries do you use?
Jérôme
cristiandinu
MessageSujet: Re: Black knight F3p 11g   Mar 2 Déc - 10:08
hi,
I have tested "by hand" Very Happy the motor and seems to hover at 60-70% throtle so i think is ok for F3P .. i will try the Aito in this configuration in this weekend
I use 400 mah from thunder power . The batteries are lighten with no cover and lighten wires and it weight 24 grams . I think i will use finaly Flight Power 350 mah 21 g
I might try to get some weight of it ... only from rudder (milled i loose 1 g ) and the antena maybe .. 1 g now the receiver has 5 g but that's all . With the batteries and milling and antena I will loose another 5 g ... So i'm not even near your weight
Strange thing about the material. The 2 parts of the fusselage .. one has 14 g and the other one 12 g ..
Thanks for your quick response..
Cristian
Page 1 sur 2Aller à la page : 1, 2  Suivant
» Buste CHEVALIER NOIR "retro" (Black Knight)
» CHEVALIER NOIR "D.Whitman / exclu" (Black Knight III)
» Black Knight, Transport Alexandre Chevallier (Roussillon, 38)
» CHEVALIER NOIR "D.Whitman / classic" (Black Knight III)
» White Knight, Black Swan
